Old 12-11-2013, 05:54 PM
Default Is there any sane way to put discs on 67 Cutlass?
What would be the best way to put discs on the front of a 67 Cutlass without trying to source some kind of 1 of none parts,or buying 13" bling bling brakes? I would be interested in anything that fit under 15" wheels,and even more interested in if it used parts sourced from OEM applications,especially if it didnt involve cutting or welding factory parts. So is there a way? Thanks.
Old 12-11-2013, 06:00 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Default Re: Is there any sane way to put discs on 67 Cutlass?
Maybe one of these kits would work?
http://inlinetube.com/disc%20brake%2...ion/dbrake.htm
http://www.ss396.com/mm5/merchant.mvc?Sc...ECONVERSIONKITS
Jake
Jake Dykstra
Dykstra Motorsports
Old 12-11-2013, 06:42 PM
Canuck's Avatar
Canuck Canuck is offline
Any setup including spindles from 70-72 A body and Nova will work.
That is what these kits are based on.
Paul
www.vancouverclassiccars.com
Old 12-11-2013, 09:48 PM
marxjunk marxjunk is offline
scarebird is a cheap safe way....
Mark
Old 12-11-2013, 10:50 PM
----Rich,,,67 Cutlasses were available with a disc-brake option. I believe Inline Tube stocks every piece you need for the conversion. The 67 option had Corvette style calipers but I think you can buy all the stuff from Inline to convert to a 69 style set-up as well. Give them a call. Cant hurt!.....Bill S
Old 12-12-2013, 06:21 PM
Alss's Avatar
Alss Alss is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Canuck</div><div class="ubbcode-body">Any setup including spindles from 70-72 A body and Nova will work.
Paul
</div></div>
X2
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 12-12-2013, 06:31 PM
O.K.,thats a little better,because I heard that the 68 and later stuff was totally different in every way. Not that the stuff is easy to find,but at least if I find the spindles,I can get the rotors and calipers from a local parts store. Of course I would want a correct dual master for the disc brake application,I would run a dual master even if I kept stock drums,the single pot is scary.
Old 12-12-2013, 06:41 PM
Both those kits are excellent,the 2nd one has a price that is probably cheaper then buying half the parts seperatly. Thanks.
