Old 11-25-2013, 11:53 PM
Default 1968 L-88 427 Shortblock Standard Bore Super Clean
1968 L88 427 Shortblock
This shortblock came from an estate that was being cleaned out by HASMAT due to oil, etc on the property. Thank goodness this engine was saved before it was sent to the scrap yard. Who knows how many cool parts didn't survive.
There was also a flat bottom boat with an L-88 engine it in on the property. I was not lucky enough to get that. I imagine this shortblock was a spare for the boat.
This engine looks to have been run for very short period of time. It is standard bore with no ridge on top of the cylinders and clear broach marks visible in every cylinder. One piston and rod were missing from the shortblock when I got it. I have since located the correct piston and rod which are included with the engine. I am not sure if the piston and rod were robbed from the shortblock for the engine in the boat or if the piston was damaged due to a dropped valve, etc. The cylinder with the missing piston is excellent with no damage.
The numbers on this engine are as follows:
Block: Casting- 3916321 Date Code- L 18 7 Pad Stamp- CE862626
Crank: Forging number 7115
Rods- Dimple with 3/8 bolts
Pistons- Std Bore Forged GM 3906648
Original standard bore L-88 shortblocks rarely come up for sale. This shortblock also came to me with these heads that I currently have on Ebay:
3919842 Heads
I did not keep these heads with the engine since the chambers have been opened up. I would sell these heads with the engine for an additional $2000. I also have unaltered 3919842 heads available.
This is an awesome standard bore shortblock.
$3750 for the shortblock
