Old 11-02-2013, 02:16 PM
napa68's Avatar
napa68 napa68 is offline
Default Mechanical temp gauge going bad??
After getting my 67 Nova running again, I am having trouble with the SW mechanical temp gauge jumping ALL over the place...............like from 160 to 200 in a matter is a few seconds and then settling back down. Only to jump around a little more (perhaps not quite as drastic). I have checked block and cylinder head temp with a temp gun and the temp seems to be stabilized as well as consistent. Additionally, I have checked the coolant for hydrocarbons and that is clear (bad head gasket). The system has been burped so that is fine.
I am not sure if I pinched the capillary tubing while working on the car? Any similar experiences or advice? This is an NOS gauge that has been in the car for around 7 years and the engine has never exhibited this type of behavior.
Tim
Old 11-02-2013, 03:36 PM
TDW TDW is offline
Default Re: Mechanical temp gauge going bad??
Thermostat is most likely sticking.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 11-02-2013, 04:21 PM
Plowman's Avatar
Plowman Plowman is offline
I put a 1/8" in all my thermostats but the "HOT SET UP" is a EPM/Stewart High-Flow Thermostat and they also have three 3/16 machined bypass holes to allow some coolant through even when closed-perfect for high--rpm engines too.
Old 11-02-2013, 04:53 PM
I would try another gauge Napa. See where that takes you.
Old 11-02-2013, 10:21 PM
69VN's Avatar
69VN 69VN is offline
Check to see if you have enough coolant in your radiator if you have already done all of the above!
