Old 10-25-2013, 02:35 PM
Steve Shauger's Avatar
Administrator
Default 1969 Cowl Induction Spacer Z28
Looking for an orig Demco cowl induction spacer # 3955233 used on Z28.
PM or call 631-514-9765
www.yenko.net
www.vintagecertification.com
Old 10-25-2013, 02:55 PM
enio45 enio45 is offline
Default Re: 1969 Cowl Induction Spacer Z28
steve - is it stamped demco somewhere on the spacer...I have several nos ones from the late 70's, just need to check this demco thingi ?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 10-25-2013, 03:20 PM
Yes
Old 10-25-2013, 04:19 PM
Here's what he's looking for.
Old 10-25-2013, 05:00 PM
Administrator
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: enio45</div><div class="ubbcode-body">steve - is it stamped demco somewhere on the spacer...I have several nos ones from the late 70's, just need to check this demco thingi ? </div></div>
Eddie, some are not stamped with Demco. I believe they are 2 1/4 inches. The SS 350 spacer is larger around 2 1/2 inches.
www.yenko.net
Old 10-25-2013, 05:02 PM
Fast67VelleN2O's Avatar
I just recently had an unstamped one.
Day 2 is Life.
Old 10-25-2013, 05:12 PM
MosportGreen66's Avatar
Hi Steve, I have a stamped one if interested?
Old 10-25-2013, 05:20 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: paceme</div><div class="ubbcode-body">Eddie, some are not stamped with Demco. I believe they are 2 1/4 inches. The SS 350 spacer is larger around 2 1/2 inches. </div></div>
302cid used extension #3955233.
350cid used extension #3955232.
Old 10-26-2013, 10:27 PM
im a little confused on the correct height of the spacer - the one on my orig late build 69Z measures 1 3/4 total height and the height of the area above the air cleaner is 1 1/8.
soooo, where is the 2 1/4 coming from or I don't have the right stuff on my car, or there are different ones.
being a late car, my cowl air cleaner has a ridge on the bottom, similar to what has been found on the late cars.
this car is a 09C car.
thoughts?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 10-27-2013, 12:30 AM
Administrator
I checked the one on my orange car and it's about two inches overall and one inch from the top of the ridge to where the flange sits. This is identical to your measurements. What you have is correct my note was incorrect (possibly for ss350).
www.yenko.net
