Old 10-12-2013, 08:43 PM
69 JL-8 69 JL-8 is offline
Default MOTOR OIL
WHAT TYPE AND WEIGHT OF OIL IS BEST TO RUN IN A FACTORY ORIGINAL 1970 L78 NOVA? THANKS, JEFF
Old 10-12-2013, 09:45 PM
427.060 427.060 is offline
Default Re: MOTOR OIL
I use Valvoline VR1 20/50 in my 427. There are several good oils with the required zinc for these engines but most are not available at your local parts store.
James
1968 Beaumont SD396
Old 10-12-2013, 10:25 PM
I use Brad Penn 20W-50 or 15W-40 in my 69 Z/28. Also Rotella-T 15W-40 is good too.
Old 10-13-2013, 12:46 AM
XXXGoldL34M20's Avatar
Valvoline VR1 20/50
With Edelbrock Zink additive.
There is an old thread on hear that we discussed the same question, but I can not find it to post the link.
Old 10-13-2013, 02:31 AM
Found the old Link Motor Oil
Old 10-13-2013, 03:18 AM
GreenLS6 GreenLS6 is offline
If your motor is built right and your clearances aren't super crazy loose you sure don't need 20-50.
I run Brad Penn 10-30 , on the dyno 20-50 cost 12hp versus the 5-20 I use during racing.
And those were Back to Back 180* oil temp and 160* water temp. So it's an apples to apples comparison.
Tim Clary
68 RS/Z28
69 Olds Cutlass S
70 Chevelle SS LS6
70 AMX 390 Go-pack
71 Torino GT 429cj
