Old 10-06-2013, 08:18 PM
CROSSRAMJL8 CROSSRAMJL8 is offline
Default REAR END SWAP 67-9 CAMARO TO 69 NOVA
Can anyone tell me if you can put a 67 Camaro rear end into a 69 Nova and have it bolt right up. are the width and spring perches the same width???
Any help would be appreciated.
Thanks
Tony
Old 10-06-2013, 08:36 PM
Fast67VelleN2O's Avatar
Default Re: REAR END SWAP 67-9 CAMARO TO 69 NOVA
Exact same dimensions and will bolt right in. 1967 has single leaf spring pads. 1969 Nova would have single leafs if it was a low cube v8 or 6cyl car but multileaf if it was a 350 396 etc.
Day 2 is Life.
Old 10-06-2013, 11:55 PM
earntaz earntaz is offline
Check the lower plate for shock mount -- other then that, Fast67VelleN20 is spot on.
The TAZ
