Old 09-23-2013, 03:46 AM
the427king's Avatar
Default Z motor for sale
A factory Z28 DZ motor for sale. factory pad,no vin on pad or alternate. All original assembly line z parts Std bore,pink rods w original pistons,windage tray and oil pan,balancer and timing cover 1178 crankshaft,E149 heads.late may stamp on pad. 472 intake,4053 carb,826527 manifolds. Much more available including 100% original smog setup,pulleys fan clutch,flat bottom air cleaner etc etc 6500.00 for long block, remaining parts available only with long block if desired.
No Fisher priced toys here
Old 09-23-2013, 06:06 PM
the427king's Avatar
Default Re: Z motor for sale
blank oil filter area. Never altered or modified.
Old 09-23-2013, 06:07 PM
the427king's Avatar
Motor mounts off motor for sale 199.00 5 original mounting bolts and both long thru bolts are included.
