Old 09-22-2013, 01:09 PM
twertsy twertsy is offline
Default '70 GTO Steering Column Rebuild
Wonder if I might get a little help. This is the original tilt steering column from my GTO. Anyone ever rebuild one of these? How do I get the lock cylinder out?
Old 09-22-2013, 01:26 PM
Default Re: '70 GTO Steering Column Rebuild
At the 2 O'clock position,there's a cast metal slot you have to break.Yours looks to already have been broken through.
Once you break through,you insert a tool,(I use hacksaw blade),and depress the slim spring loaded button while pulling on the ignition lock cylinder,and it will come out.
Watch this @ the 2:35 and 3:00 mark:
<object width="425" height="350"> <param name="movie" value="https://www.youtube.com/v/MD-mQuiqgwc"></param> <param name="wmode" value="transparent"></param> <embed src="https://www.youtube.com/v/MD-mQuiqgwc" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
Old 09-22-2013, 02:02 PM
Great video! However, I don't feel anything spring loaded in there, and it still won't come out. See the pic below. It appears this little clip on the other side of the column has tension when I pull on the cylinder. However, I've depressed it, as well as pulled it and it doesn't seem to release.
Old 09-22-2013, 02:09 PM
Nevermind.........thanks a bunch Mr. 70, I just didn't pull hard enough. Success!
Old 09-22-2013, 02:23 PM
Ok next issue........any special trick to getting the cover off once the cylinder is out? Appears to be a little spring blocking removal. Don't want to break anything as I'm refurbishing the entire column.
Old 09-23-2013, 08:26 PM
smoke' em II's Avatar
smoke' em II smoke' em II is offline
Everything you will ever want to know about steering columns and more. BTW, Jim Shea is a retired Saginaw engineer.
http://jimshea.corvettefaq.com/
ACES #08588
OCA #28054
1970 Chevelle SS
1970 Olds 442 Survivor
1997 SVT Cobra convertible
Old 09-23-2013, 09:25 PM
Thanks much Smoke!
Old 09-24-2013, 06:55 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: twertsy</div><div class="ubbcode-body">Thanks much Smoke!</div></div>
[img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
ACES #08588
OCA #28054
1970 Chevelle SS
Old 10-02-2013, 12:51 AM
BlueSS454's Avatar
BlueSS454 BlueSS454 is offline
Send a message via AIM to BlueSS454
I have rebuilt a number of GM tilt columns. The lock is the easy part! You need special tools to pull it the rest of the way apart. One to remove the pivot pins on the side of the column head, then a torx socket to remove the piece under the head. I have one apart in the shop now if you need pics of anything.
Tom Rightler
Vice President, Maryland Chevelle Club
MCC Newsletter Editor
1970 SS 454
1970 SS 454 Convertible
1969 Malibu
Old 10-02-2013, 12:59 AM
Wow, thanks Tom.....what's the special tool and where do I snag one? Carlisle? Those pins have been driving me nuts!
