Old 08-29-2013, 03:54 PM
Edgemontvillage's Avatar
Edgemontvillage Edgemontvillage is offline
Default 1969 Camaro Original U Joint
<span style="font-size: 14pt">Back in the market- still need 1 assembly line correct 1969 Camaro u-joint with Bow-tie casting in center (M22/12bolt). I have one, need another. Must have good rubber, please PM with details. Thought I had one located, didn't work out. Thanks. </span>
Old 08-29-2013, 08:24 PM
galveston's Avatar
galveston galveston is offline
Default Re: 1969 Camaro Original U Joint
What trans?....400?...350/Muncie?
Shaun
Old 08-29-2013, 10:10 PM
enio45 enio45 is offline
69Z - Muncie 4 sp
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 08-29-2013, 11:03 PM
scuncio's Avatar
scuncio scuncio is offline
Trans shouldn't matter, right? I think all MY69 Chevy passenger car joints were 1310 size.
Old 08-29-2013, 11:49 PM
John Brown's Avatar
Trans matters sometimes. The joints on TH400 are often different, including some that have two different size caps.
John Brown
Old 08-30-2013, 01:35 AM
<span style="font-size: 14pt">Still looking for 1 assembly line correct 1969 Camaro u-joint with Bow-tie casting in center (M22/ 12bolt). I have one, need another. Must have good rubber. Please PM with details. Thought I had one located, didn't work out. Thanks. </span>
Old 11-21-2013, 06:23 PM
<span style="font-size: 14pt">Still looking.</span>
Old 11-21-2013, 08:46 PM
marxjunk marxjunk is offline
is the other side marked the same way? or a part number? i know someone that might be able to help i sent him your pic...
Mark
Old 11-21-2013, 10:07 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: marxjunk</div><div class="ubbcode-body">is the other side marked the same way? or a part number? i know someone that might be able to help i sent him your pic... </div></div>
<span style="font-size: 14pt">Bow-tie emblem is cast on one side only, no part number anywhere. </span>
Old 11-22-2013, 02:22 AM
ok, i will email him and see..not sure i can help but i will try
Mark
