Old 07-28-2013, 10:58 PM
Default Hurst shifter handle
I put a Hurst shifter in my bench seat, 69 big block Nova project car. The chrome handle looks like a one size fits all piece. Does anyone know if there is a more correct shaped handle available?
69 El Camino
69 Nova
C7 Vette
Old 07-28-2013, 11:48 PM
crash crash is offline
Default Re: Hurst shifter handle
What shifter and install kit are you using ??? Crash
Old 07-29-2013, 02:09 AM
Hurst Shifters 3916848 - Hurst Competition/Plus Shifter
It's the shifter they list for the bench seat Novas. There's nothing wrong with the shifter. I'm wondering if someone makes a stock looking handle, that is like what GM used in 69.
Here's a shot of the shifter.
Here's a shot of a members Nova shifter. This is what I'm looking into.
69 El Camino
69 Nova
C7 Vette
Old 07-29-2013, 09:26 AM
jasonL78 jasonL78 is offline
Bill this is what you need to do.
Find an old shifter handle cut off the bottom and weld on the hurst bottom.
Just did it for Tom Williams a couple months ago.
The second shifter is the one he gave me to use as a template.
Of coarse I had to grind my weld dowm.
Looking for the next project.
Old 07-29-2013, 01:33 PM
Thanks Jason. Great pictures/explanation. I thought maybe someone made the correct handle, like you can get for Chevelles. Ground-Up sells a Muncie handle that fits the Hurst shifter, but the Chevelle handle is straight at the bottom, so it's just a matter of cutting the bottom off, and drilling 2 holes.
I'll start looking for a Muncie Nova handle. I wonder how close the bench seat Chevelle handle is to a Nova handle. They're easy to find. I have the Hurst shifter handle, to use for the bottom. I just need the Muncie handle to graft it to.
69 El Camino
69 Nova
C7 Vette
Old 07-29-2013, 01:41 PM
marxjunk marxjunk is offline
youd be better looking for a 67 camaro muncie shifter than a chevelle, the chevelle shifter has a bigger hook and will hit the dash on a power shift, and it looks out of place and huge...i built 5 Novas in a row in the late 90s and experimented a lot..the camaro one worked best
Mark
Old 07-29-2013, 02:05 PM
JoeC JoeC is offline
I have done a bunch of the Muncie stick conversions and I just cut it off and drill the holes. I may have an extra Nova Bench Muncie stick as I have a bunch of Camaro Chevelle Nova Muncie shifters.
the 69-70 Nova used the 67-68 Camaro mount plate that you have but the 71-72 Nova used the Chevelle install kit with the 7773 mount plate and it locates the shifter higher on the trans.
Old 07-29-2013, 09:36 PM
69VN's Avatar
69VN 69VN is offline
Don't know if this will help Bill but try DRCLASSICS. Here is the link:
https://www.drclassic.com/catalog/Ca...Z20028-M7.html
SAL
Old 07-29-2013, 11:04 PM
TDW TDW is offline
Bill, take a look at this site. They have a few different handles. I have heated the handles up and bent them before. The chrome turns blue, but I have a Baldor polishing wheel that I can get the bluing off with. It works for me, but someone will probably argue about doing it that way.
http://www.spiderautomotive.com/hurststick.html
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 07-30-2013, 03:58 AM
Thanks a lot for all the ideas. I have some homework to to. It's not something I have to do right away. It's a simple switch to make, once I have the handle ready to go.
69 El Camino
69 Nova
C7 Vette
