Old 07-15-2013, 11:47 PM
gschevy gschevy is offline
Default 1967 396 camaro engine
I have a 396 325 hp big block chevrolet engine complete from carb to pan i have never had it apart so i dont know the bore or if its ever been rebuilt . Engine code shows its out of a 1968 camaro with 4 speed transmission . If your a serious buyer i will get the numbers and any info you need . Here is your chance for a 396 for that classic camaro . I work alot so its best to Email here or text 316 five58 o3six8 thanks No i will not ship or cash your check or work with your shippng guy this is a face to face transaction cash UPDATE Block casting number 3902406 stamp code to626mw mw vin 7n249050 code shows 1967 - 1968 camaro 4 speed or auto . exhaust manifold numbers are 3909880 and 3909879 that shows 1967 . heads are 3917215 oval port closed chamber 109 cc date f 19 7 . distributor tag is 1111138 shows 1966 . intake is 3883948 1966-1968 . carb is not the right date .It spins over by hand shows signs of compression . This all showing a build date of july 1967 so late 1967 camaro or early 1968 camaro . It does have correct alt brakets and power steering brackets and pulleys $1500 firm
Old 07-16-2013, 12:07 AM
Default Re: 1967 396 camaro engine
Sounds like a very fair price for what is there but you might want to fill out your profile and follow the rules of listing (become a member) before it gets removed. It would also help if you told people where you live so they will know what it takes to be face to face.
