Old 07-14-2013, 07:14 AM
Default how do I remove rattle can trunk spatter paint
I'm hoping to reveal as much of the original trunk as possible in a survivor, and even bare metal would be better than the thick chunky coat of spatter that has been sprayed over the original finish. Any ideas or suggestions?
Thanks!
Old 07-14-2013, 11:20 AM
Woj's Avatar
Woj Woj is offline
Default Re: how do I remove rattle can trunk spatter paint
There is a member here (Grady) that did it to onw od his 69 Chevelles with complete success. The results were stunning. The rattle can spatter that was put over the original was not clear coated, so he was able to remove it with a high strength over the counter cleaner. I believe it took about 8 hours, but was well worth it as the original spatter was 95% there and in great condition.
Phil Woj.
Old 07-14-2013, 08:30 PM
BillD BillD is offline
I did what you are asking about and had pretty good results. I sprayed Meguiars Quik Detailer onto the rattle can paint and let it soak in and then brushed it and then wiped up the slop with rags. It took repeated applications but I finally got most of it out and it looked pretty good when done. I must have had 8-10 hours into the project. I was afraid to use anything stronger than the detail cleaner so maybe someone knows a better product to use.
Old 07-14-2013, 11:20 PM
mockingbird812's Avatar
Good to hear Bill. Any pix you can share? What does this say about Meguiars detailer and our cars' paint!!! [img]<<GRAEMLIN_URL>>/shocked.gif[/img]
Sam...
Old 07-15-2013, 01:16 AM
Mr. Chevy's Avatar
Spray Nine was the cleaner Grady used.. It can be bought at the hardware store..
Rich
Old 07-15-2013, 01:55 AM
1969grb 1969grb is offline
Thanks Rich, I could not remember the name of the cleaner.
Helmut Spray Nine did a great job. You can not tell the original trunk paint had been painted over.
Grady
Old 07-15-2013, 02:06 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: mockingbird812</div><div class="ubbcode-body">Good to hear Bill. Any pix you can share? What does this say about Meguiars detailer and our cars' paint!!! [img]<<GRAEMLIN_URL>>/shocked.gif[/img] </div></div>
I believe the rattle can paint is water soluble, which is the reason the cleaners work to get rid of the spatter paint. The car that I did this to is now gone, so I can't share a photo.
Old 07-15-2013, 02:10 PM
Good info Grady. Would you please give us a recommended hardware store to use? [img]<<GRAEMLIN_URL>>/whistle.gif[/img]
Sam...
Old 07-15-2013, 08:48 PM
Jack_Tar Jack_Tar is offline
Rattle can materials often times will come off with some wax &amp; grease remover. A little stronger stuff, an acquaintance of mine had a car that was stolen and recovered several months later that had been sprayed with black primer and he used lacquer thinner to get it off of the entire car. It needed a buffing and waxing after that, but all in all, not bad. Could have been disastrous though.
Jack Tar (Old English Slang for Sailor)
Old 07-15-2013, 10:31 PM
Ace is the place with the helpful hardware man (Grady). [img]<<GRAEMLIN_URL>>/wink.gif[/img]
