Old 07-05-2013, 03:23 AM
Default Power steering hose routing
I can't seem to figure out where the power steering hoses should be routed in a BB 69 Nova. The assembly manual isn't clear on this one. Can someone post a pic or 2 showing the p/s hose routing, or maybe a good description.
69 El Camino
69 Nova
C7 Vette
Old 07-05-2013, 09:34 AM
parkbrau's Avatar
parkbrau parkbrau is offline
Default Re: Power steering hose routing
They go under the engine mount/tower but not through it. Is that where your stuck? I can see what you mean by the AIM. Do you have a 69 Camaro AIM? Sheet A6 is a bit better than the Nova sheet.
The mount tower is bolted to the subframe and if you lean over the driver fender and pass the hoses behind the tower and above the subframe they will be in the correct location. The hose strap (looks kinda like the heater hose strap on the passanger inner fender) mounts to the lower mount bolt accessable on the left of the tower, if you are still leaning over the fender. And it looks like you still have the clamp on top of the gear box, thats the high pressure hose clamp.
Good looking power plant BTW.
Edit: Not speaking from experience while working on my BB Nova (It aint got PS). 69 Nova PS hose routing is the same as Camaro.
Old 07-05-2013, 11:31 AM
m22mike's Avatar
m22mike m22mike is offline
Bill
I sent you a scan from the 69 Camaro AIM. Would not post here, wrong format I think.
Mike
Old 07-05-2013, 04:30 PM
Problem solved. Thanks John & Mike. I don't have the Camaro assembly manual, but Mike sent me the aim page, and that's a bit easier to see. The lines are in, but I have to get the clamp. Thanks again!!
69 El Camino
69 Nova
C7 Vette
