Old 06-23-2013, 02:34 AM
Woj's Avatar
Woj Woj is offline
Default 12 Bolt , A-Body rear after grease removal
I'm putting a 12 bolt into a project car that I'm finishing up. This rear end came from Colorado, so it is very clean. It must have been a leaker from the beginning because of a generous build up of grease and dirt around the differential housing. The finishes were pretty good, so I thought it might be interesting to see the raw finishes around the center of the rear with a few inspection marks revealed. Here goes:
Old 06-23-2013, 02:42 AM
mockingbird812's Avatar
Default Re: 12 Bolt , A-Body rear after grease removal
Wow, very pristine. What did you use to clean it Woj?
Sam...
Old 06-23-2013, 02:56 AM
Woj's Avatar
Woj Woj is offline
Sam,
I used engine degreaser, kerosene and a soft bristle brush. What a messy job. I should have taken a before picture.
Phil Woj
Old 06-23-2013, 04:58 PM
Fast67VelleN2O's Avatar
Wow gorgeous original housing!
Day 2 is Life.
