Old 06-18-2013, 09:31 AM
twertsy twertsy is offline
Default Seeking Suggestions
Well, I put this in the Pontiac area but got no advice so I'll elevate(?) to here. I'm seeking recommendations for my '70 GTO on suspension upgrades. I can't find the original engine so I'm building it the way I want it, to be driven and driven hard.
I want it to drive/ride like a modern muscle car, with a pro touring flavor. 505CI supercharged Butler going in backed with a modern 5 or 6 spd manual and GM 12 bolt rear. I've looked at the Hotchkis TVS Stage 2 but really can't seem to find any other "complete" suspension packages. Are there any other vendors offering this or similar/better setups? Experienced A body recommendations greatly appreciated! Thanks in advance.
Todd
Old 06-18-2013, 10:44 AM
wheelhop wheelhop is offline
Default Re: Seeking Suggestions
Detroitspeed.com
Old 06-18-2013, 12:52 PM
Pulnaway Pulnaway is offline
There are quite a few companys out there offering suspension systems. At the end of the day it depends on what your going to do with the car. I like the ridetech systems for overall handling and ride comfort. Unless you are a hardcore corner carver you will not be happy with alot of the rougher suspension systems on the street.
Scott
Old 06-18-2013, 12:59 PM
Appreciated folks. I'm looking at this one right now. Any thoughts or warnings? No "hardcore corner carving," but I do want it to be able to handle corners with ease and without the older car "pitch and roll" on entry/exit.
Old 06-18-2013, 01:42 PM
I think that setup will do what you want. John Hotchkis is a good guy and I would have no problem listening to his suggestions.
Old 06-18-2013, 02:36 PM
Thanks. By the way, enjoyed the first muscle car show. Beautiful cars.
Old 06-18-2013, 08:57 PM
427.060 427.060 is offline
Check with UMI Performance. Quality parts and service. Their parts are made in the US. One of their test cars is a 72 Lemans.
James
UMI Performance
1968 Beaumont SD396
Old 06-19-2013, 02:39 PM
SOM2001SS's Avatar
SOM2001SS SOM2001SS is offline
I really like Hotchkis products. I would definitely have the Hotchkis TVS system on my Chevelle if I had the money. I have lots of Hotchkis parts on my 2001 Camaro SS.
1970 Chevelle SS454 Fathom Blue, 01 Camaro SS Sunset Orange Metallic, 65 Plymouth Belvedere vert
Old 06-19-2013, 02:46 PM
Anyone have any experience with Ridetech?
John 10:30
Old 06-20-2013, 12:56 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: markinnaples</div><div class="ubbcode-body">Anyone have any experience with Ridetech? </div></div>
I guess we will find out, that's what I went with.
- ridetech front and rear coilovers front a-arms, rear upper and lower arms and drop spindles
- ridetech brand (the ridetech front sway bar is splined and comes with posi endlinks which will eliminate any bind between the sway bar and control arm)
- 4 wheel disc brakes, 11” booster, master and prop
grey powder coated calipers
drilled/slot/zinc rotors
stainless steel braided hoses
stainless steel hardline kit
I greatly appreciate all the ideas. Thank You.
