Old 06-03-2013, 12:28 AM
russgt russgt is offline
Default 12 bolt axle code
Hi guys, I think that the stamp code that I am seeing is "BR" and not "RR". what do you think?
Old 06-03-2013, 12:31 AM
Jonesy's Avatar
Jonesy Jonesy is offline
Default Re: 12 bolt axle code
BR is what I see
Old 06-03-2013, 12:51 AM
mike70ss mike70ss is offline
The character is curving, unlike the "R". Appears to be a "B"
1970 Super Sport Chevelle Enthusiast and Restoration
L34, L78, LS5, LS6
427 engine... oval port and square port builds
Muscle Car Mechanic and Engine Builds.
Old 06-03-2013, 12:59 AM
Can anyone decipher the rest of it? It came in my 71 nova ss and I was trying to figure out if it was original to the car.
69VN's Avatar
69VN 69VN is offline
Definitely BR.
Old 06-03-2013, 04:01 AM
69 Post Sedan's Avatar
If its a leaf spring rear end than it appears to be a 3.07 open for a Nova.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 06-03-2013, 05:47 AM
John Brown's Avatar
CRG shows a BR axle is a 3.07 <span style="text-decoration: underline">with</span> Positraction. http://www.camaros.org/drivetrain.shtml#AxleCodes
After 1969 axle codes usually had a three letter identification, like CBR instead of just BR.
John Brown
Old 06-03-2013, 11:47 AM
Yes John, you're correct...it is a 3.07 Posi......I read it wrong.
That rear end code is correct for a Nova also. Nova Resource
What is the casting date?
Kurt
Old 06-04-2013, 01:16 AM
The date code is illegible, here are some more pictures of it.
