Old 05-23-2013, 02:25 PM
GaryC's Avatar
GaryC GaryC is offline
Default 4777 650 dbl pump
Hey guys. I have a 4777 650 dbl pump carb I only used for a few hours at the most. All the fuel was removed and I wrapped it up and boxed it away so it's been out of the elements. I'm not going to use it so if there is anyone that can send me a PM with an offer.
Gary
Old 06-10-2013, 10:24 PM
GaryC's Avatar
Default Re: 4777 650 dbl pump
Sold pending payment.
Gary
Old 06-13-2013, 07:22 PM
GaryC's Avatar
Sold
Gary
Old 09-17-2013, 03:51 AM
Jeff H Jeff H is offline
Hey Gary, I finally got around to putting the carb on the speed skiff this past weekend. I put in some 76/78 jets and replaced the power valve just in case and took it out for a run. Wow, the boat jumps up to speed so much quicker than the 750 vac secondary carb!
Old 09-19-2013, 02:14 AM
GaryC's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Jeff H</div><div class="ubbcode-body">Hey Gary, I finally got around to putting the carb on the speed skiff this past weekend. I put in some 76/78 jets and replaced the power valve just in case and took it out for a run. Wow, the boat jumps up to speed so much quicker than the 750 vac secondary carb!
</div></div>
I'm glad the carb worked out for you Jeff. The pic is sweet man. There's something about a dbl pumper you gotta like.
Gary
