Old 05-21-2013, 03:52 PM
foster foster is offline
Default heat shield, quadrajet
the thin heat shield that goes on the the quadrajet,s should under the base plate of carb. or down on the manifold face down? [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
1967 SS CHEVELLE SURVIVOR
1968 SS MATADOR 396 CAMARO
1967 CAMARO SURVIVOR
Old 05-21-2013, 04:15 PM
VintageMusclecar's Avatar
Default Re: heat shield, quadrajet
The gasket goes on the intake first, then the stainless shim, and the carb on top of the shim. Note the gasket and the shim both only go on one way.
Old 05-21-2013, 09:06 PM
thank you eric i thought thats way it goes been messing with theses carb,s for a long time should had known thanks again eric
Old 05-21-2013, 04:23 PM
earntaz earntaz is offline
CAUTION -- Just make sure none of the linkage hangs up on the shield!! Stuck at WOT sucks!!!
The TAZ
Old 05-21-2013, 06:37 PM
I believe they are talking about the thin gasket that goes with the cardboard gasket. Nothing aftermarket or unstock if I am reading it correctly Taz.
Old 05-21-2013, 07:51 PM
The closer I read that I think you're right -- at first, it looked like foster was talking about the heat shields that covered a portion of the intake. Good catch! The TAZ
