Old 05-07-2013, 05:41 PM
madden madden is offline
Default 1970 yenko duece part #
hi
recieved tremendous help from a number of you already
need some more ifno if possible please
i need all the LT1 engine GM part numbers
-heads
-intake
-water pump
-distributor
-coil
-4 spd carb
-water pump and crank pullies
-altenator
-alternator bracket
-harmonic damper
-timing cover
-oil filter
-thermostate housing
-spark plugs
-spark plug leads
-radiator shroud
-fuel pump
-fan and fan spacer
cant think of any thing else...need the numbers so i can check what on my engine is correct and what i need to search for
thanks so much guys
regards
citrus chris
1970 citrus Yenko Nova
