Old 05-02-2013, 04:08 PM
dlv4540 dlv4540 is offline
Default 1966 -71 396 427 & 454 Blocks & Parts
1969 427 4 bolt 60 over block cleaned and magged casting number 3963512 dated L-28-8 $2000.
1969 427-435HP block #3935439 dated F-14-8 stamped T1011LX 19S70738. This block is all machined with new freeze plugs and cam bearings freshly bored 60 over and has two sleeves. The block was pressure tested along with being cleaned and magged $2500.
1969 396-375HP 4 bolt rebuilt shortblock casting 3955272 dated H-9-8 30 over $2500.
6223 steel cranksahft freshly turned 10 under $300
7/16 dimple rods $300
3919840 square port heads rebuilt dated E-18-7 & E-23-7 $2500
3919840 square port heads I-17-8 & I-30-8 stock set cleaned and magged will need new seats $1250
3919840 square port heads both dated B-20-9 stock set cleaned and magged $1250.
3919840 square port singles H-23-7, I-18-7, A-12-8, C-18-8, F-18-8, G-31-8, J-29-8, C-27-9 and D-30-9 $625 each all cleaned and magged.
3919840 square port heads both dated D-23-8 $1250
1970 454 2 bolt block 30 over with one sleeve casting 3963512 dated J-21-9 stamped 10A121807 T1121CRT $1500.
1971 3994026 square port heads both dated I-9-71 $1000.
1969 3933163 aluminum intake 6-17-69 $450
1969 3933163 aluminum intake 4-30-69 $450
7/16 rods $100
1966 3885069 aluminum intake 12-2-65 $300
1968 3885069 aluminum intake 11-20-67 $300
330-770-2517
Dennis Vugrinovich
