Old 04-15-2013, 04:16 PM
69VN's Avatar
69VN 69VN is offline
Default 1969 Camaro Used Original GM Vented Gas Caps
These are (2) used original GM vented "S" gas caps for sale. They were both removed from a 1969 Camaro and are the same size. Both are in pretty good condition. One has been cleaned up and the other has not. Both need to be replated and need the rubber gasket replaced. Notice that one gas cap has bigger stamped lettering as the other has the smaller lettering. And notice the inverted turn handle is different on both along with the positioning of the ears. I believe these can be used on other Chevy makes and models but do your homework first. Being sold as each. *Asking $30 each plus shipping to lower 48 states. PM me with any questions. Thanks.
