Old 04-14-2013, 11:41 PM
Default 1969 Camaro Brake Line Clips (without tabs)
Need some help here......
What color should the brake line clips be that are in the lower portion of the front subframe cross member? See below.
These clips do not have a mounting tab.
I have been told clear zinc (like a shiny steel finish), is that correct?
Thanks
Old 04-15-2013, 08:14 AM
69VN's Avatar
69VN 69VN is offline
Default Re: 1969 Camaro Brake Line Clips (without tabs)
HBC has these 3/16 clips being gold iradite plating.
Old 04-16-2013, 03:46 AM
Hello,
The 3/16 with tabs were gold. Makes sense that the with out tabs could be too.
Greg
Old 04-18-2013, 11:00 PM
Thanks to all.
