Old 04-08-2013, 03:33 AM
Default Gabriel Gas Adjust rear shocks 68-69 Camaro
I know these have many other applications. Part number 733505. Made in USA.
Slightly used. I have had them many years, stored indoors, and partially collapsed as they should be. They are not really a high performance shock in my opinion; more of a comfort shock, but are worlds better than the original spirals.
These will fit either mono or multi leaf. The only difference is the bottom rubber.
They had the large hole rubber for multi leaf. I robbed the rubbers out of the bottom eyelet to use on my Koni's. I will include the correct rubber for mono leaf if you want, or you can get the correct ones for multi leaf.
These are free for use on your own car.
You will pay only actual shipping.
