Old 04-05-2013, 03:42 PM
Default Pnuematic/hydraulic body jacks/lift
Advanced Performance Engineering Air-Powered Hydraulic bumper or body lift-- 1 1/2-Ton Capacity, Model# 14520/ABJN
Ratcheting safety bar locks the jack if air pressure is lost. Single-handle control for automatic up, manual down. U.S.A. Lift Capacity (tons): 1 1/2, Min. Lift Height: 8", Max. Lift Height: 35", Operation: Air, Working Pressure (PSI): 80 - 150, Air Inlet Size (in. NPT): 1/4"
* 1 1/2-ton capacity
* 3-way heavy-duty air valve
* Requires 6 CFM
* Lift pad spread: 36in. to 57in.
* Forward reach: 21in.
* 8in. diameter pneumatic rear wheels
Can be used as bumper jacks also but I used for lifting bodies off of cars (see photos). This is a very affordable alternative to buying a lift and takes up very little room when not in use. I purchased a 2 post and a 4 post lift so I no longer need these are they are in great condition. Can be used on concrete, blacktop, dirt, grass, etc with pneumatic tires. Easy to move around and store. New these sell new for $900 each. I am asking $900 for the pair. Now you can do your own restoration at home without the aid of a post lift. Can be freight shipped if you line up the shipper. Can be seen an tested at MuscleCar Restoration and Design in Pleasant Plains, IL. Call 217-626-2277 or email [email protected] for questions
Old 05-12-2013, 11:34 PM
Default Re: Pnuematic/hydraulic body jacks/lift
SOLD!
Thanks sYc
