Old 03-19-2013, 10:54 AM
69VN's Avatar
69VN 69VN is offline
Default Used GM Motor Mounts 1969 350 Engine
This is a used original pair of GM motor mounts removed from my 1969 350 engine last year before the rebuild. The steel is solid with no cracks, welds or defects...just some surface rust and some cleaning needed. The rubber is ok...one side better than the other. See photos on the extent of wear and tear. Would probably be good for a daily driver. *Asking $35 with shipping included to lower 48 states/Canada extra. Pm me with any questions. Thanks.
