Old 01-31-2013, 05:25 AM
Default Repro throttle arm for ducted hood car
I have an unused throttle arm without a scratch.
Just in case you don't know the diff between the original and the repro, the repro has the pinch bolt welded in at the back side. Also, even though the bolt and nut are the correct 1/4 inch coarse thread, the nut is a 10mm hex instead of a 7/16. Other than those two things, it is pretty hard to distinquish from an original.
Price is right.
Free.
Send PM with address.
I will post when it is no longer available.
