Old 01-20-2013, 06:26 PM
WorkinProgress WorkinProgress is offline
Default 1969 power steering box wanted
1969 power steering box dated 048 9 stamped on top aluminum cover. Want a clean unrestored box with casting number 5691676. Looking for the 048 9 date only. Call 860-806-0347, or email [email protected]
Thanks, Warren
Last edited by WorkinProgress; 09-09-2017 at 09:45 PM. Reason: Phone number change
Attachments - The Supercar Registry NewImage_800_450_90.jpg NewImage_800_450_90(1).jpg 002.JPG
Old 01-22-2013, 10:17 PM
Ngtflyr Ngtflyr is offline
Default Re: 1969 power steering box wanted
Close but no cigar.... I have a 023 9 dated PS box
Dave
Old 09-04-2017, 09:19 PM
Is the 5691676 casting power steer gear from my 73' Camaro project
same as, same ratio as early Nova, Camaro (68-70??)............ 5691676
As I'm wanting to use the above Nova box on my 73.......Same exterior look !!!!!!!!!!
Original 73' Camaro box main shaft splines damaged in collision
Thanks
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 09-04-2017, 09:48 PM
I'm rebuilding one right now,that the customer has yet to give me the top cover for.Once it & he arrives,I'll ask him.
Old 09-06-2017, 02:55 PM
JKZ27 JKZ27 is offline
Warren, did you ever find your dated box after almost 5 years?
There appears to be one in my 68.
Old 09-09-2017, 06:22 PM
Steve Shauger's Avatar
Administrator
I just spoke with Warren, and he's still looking for the dated power steering box.
www.vintagecertification.com
Old 09-09-2017, 09:29 PM
No luck here from the gentleman I referenced earlier.
Old 09-09-2017, 09:35 PM
If you find a box in the right range, with the correct casting number, you can always transfer your aluminum cover to the new box. I have a few here, and will check dates and casting numbers.
Old 09-09-2017, 11:03 PM
Here is the gear I have. Not real pretty though.
Old 09-09-2017, 11:25 PM
I have a box where the alum cover appears to have 14 9 stamped on it.
I need a good box with casting 5691676 that is applicable to
my 73 Camaro project...ANY DATE
Im thinking that I need a 71-76 Camaro box that has 13-16:1 ratio
whatever that means
Chuck Sharin
[email protected]
