Old 01-08-2013, 12:04 AM
ANDY M's Avatar
ANDY M ANDY M is offline
Default Glue problem
I have an old pair of Sennheiser headphones that work great, but the plastic broke where the can is connected to the head strap.
I spoke with the manufacturer and they weren't much help. Crazy glue or Super glue (Cyanoacrylate) reacts with the plastic and it won't bond. In fact, it won't even dry. I also tried a two stage epoxy, which took over a day to dry and then held up for only a few days.
Any suggestions? [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
I really don't want to buy a new pair. Dr. Dre has enough money already. [img]<<GRAEMLIN_URL>>/mad.gif[/img]
Andy
COPO 9561/9737 M40 X11D80
13.37 @ 105.50 on pump gas,drove it to NATL TRAILS and back [email protected] SCR22
Old 01-08-2013, 12:09 AM
Default Re: Glue problem
Try one of the Gorilla Glues.
Old 01-08-2013, 08:07 PM
ANDY M's Avatar
Thanks for the suggestion, but if you look at the bottom of the page, next to the &quot;*&quot;, it says &quot;bonds to most plastics...&quot;.
These headphones fall into the &quot;what kind of plastic is this?&quot; category. I need something that will weld the plastic and not react with it.
Any other suggestion? [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Thanks
Andy
Old 01-08-2013, 10:52 PM
I used my plastic welder to fix the Chrysler headphones that came with the built-in DVD player in our 300. My kids have slammed the car doors on them enough times that they were crunched into oblivian. No glue really holds them so I just used the plastic welder (really just a soldering iron with a flat tip) and melted them back on to the metal head band.
They are still holding up after several re-repairs over 7 years.
It sure beats paying another $300 for a new pair from Chrysler.
Here's the one I have. You can buy different plastic welding rods depending on what you have (probably ABS) but a lot of times you don't even need the welding rod, you just heat and smear the existing plastic back over the cracked area.
http://www.amazon.com/Urethane-Suppl...ef=pd_sxp_f_pt
Old 01-09-2013, 02:13 AM
resto4u resto4u is offline
try &quot;plastic surgery&quot; by shurhold. best glue i have used on plastic.
