Old 12-31-2012, 08:18 PM
69VN's Avatar
69VN 69VN is offline
Default 1969 Original Smog Hoses, Clamps, Belt
These are used GM original smog hoses removed from a running 1969 Chevelle Concours station wagon with a 350/300hp. 4spd. The large hose has GM part #3932476 ink stamped on it and measures 20 inches. The small hose has the same part number on it as well and measures 6 inches. The smog vacuum hose is correct with the white stripe and ribbed. It measures 16 inches. All three hose are in really good condition. I also have (4) original Wittek tower smog hose clamps that are 1 1/16 in size. Two of the clamps are stamped 4/68 or 4th. quarter of 1968 and the other two are stamped 1/69 or 1st. quarter of 1969. All (4) clamps had been replated in silver cadmium last year. Finally,the original smog belt reads...GM 9433646 BY .380x48.0 DAYCO42-3499. The overall condition of the belt is pretty good. *Asking $80 plus shipping for all (8) pieces to lower US 48 states/Canada extra. PM me with any questions.
SAL
