Old 12-30-2012, 06:11 PM
v8sky v8sky is offline
Default Hurst Auto Stick 1 TH350 bracket and rod
Hello,
I am interested in finding a Hurst Auto Stick 1 TH350 mounting bracket and rod.
Chris
Old 12-30-2012, 06:42 PM
396L35's Avatar
396L35 396L35 is offline
Default Re: Hurst Auto Stick 1 TH350 bracket and rod
Did you contact Hurst or find part numbers of the parts you are looking for???
Mark
Old 12-30-2012, 11:10 PM
>>Will try finding out the part#s tomorrow and will post them here if I find out.
Old 12-31-2012, 10:51 AM
69L78's Avatar
69L78 69L78 is offline
Not sure if this helps?
Old 12-31-2012, 01:27 PM
Thanks for posting that advertisement. My car is a Buick with the Turbo/Hydro 350 but will still need to find the part number for the mounting bracket and correct rod. Does anyone here on the board have this set up in their car that they can check?
Chris
Old 12-31-2012, 03:47 PM
Spoke with a representative from Hurst and they only had the part number for the whole kit, not just the mounting bracket which I am looking for.
Old 12-31-2012, 06:37 PM
396L35's Avatar
How much was the whole kit??? It might be worth while to buy the kit and save the extra pieces.
Mark
Old 12-31-2012, 09:22 PM
Are you sure the Hurst rep is talking about the "vintage" auto stick. They make a newer model called the same thing. I talked with them a few years ago about the vintage shifter set up and they said at that time they had nothing.
Now that being said, you may have found someone with better knowledge than I found. Keep us posted if they have the correct vintage parts. If you can, ask about T 400 auto stick set ups also.
Thanks, Schonye
