Old 12-27-2012, 06:33 PM
Default Nice Misc Parts
- GM 10 ˝ Inch Inspection Cover $40.00
- Mint 526 Smog Exhaust Manifold, dated C-5-9 $575.00
- Original GM Leaf Spring Shackle Plates $55.00
- 67 68 Muncie Shifter Handle $100.00
- Heater Box Cover with Blower Motor 68 dated $80.00
- 1969 October Dated Jack/Mast (9J) $100.00
- Original AC Delco Dated Voltage Regulators (9F)working condition unk $25.00
- Original AC Delco Dated Voltage Regulators (7A - 7C - 7D)working condition unk $25.00
- Original AC Delco Dated Voltage Regulators (9J)working condition unk $25.00
- Used later version 69 Mint Deck Lid with no spoiler holes $475.00
- Pair of used original 69 Camaro RS Front Inner Tubs VERY nice shape $375.00
- Mint Set of late 67 Smog Exhaust Manifolds small block $350.00
- 67 Carb Q-Jet 350ci / 295hp $175.00
- 67 Non-Smog Exhaust Manifolds small block $75.00
- 67 Dated 8’ Timing Cover 5 – 67 small block $125.00
- 67 Nova V8 Oil Pan & Dip Stick / Pump $175.00
- 67 Nova V8 Engine Mounts $75.00
- 462 Cylinder Head Dated B 14 7 Checked / Magged $125.00
- Pair 633 Front Disc Brake Calipers Dated 52nd Day $160.00
- 69 Camaro Black Door Jamb Windlace with no clips $225.00
- 67 Camaro 2 piece Black Door Jamb Windlace $175.00
- 67 #348 Camaro Master Cylinder needs rebuilt $145.00
- 69 Z28 472 Intake Manifold $475.00
- 69 Non-dripper Finned 418 Valve Covers $475.00
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
69 RS/Z28 Maroon JL8
66 Corvette Ermine White L75
Old 12-28-2012, 12:06 AM
camaro cat camaro cat is offline
Default Re: Nice Misc Parts
69 RS washer bottle plastic screw caps. How many,3 or 6? Nice shape? Also, rear spring shackle plates, nice?
Thank you
Loren
67 RS L30 3sp 10C LOS
69 RS/SS L78 M22 02D NOR
Old 12-28-2012, 03:04 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: camaro cat</div><div class="ubbcode-body">69 RS washer bottle plastic screw caps. How many,3 or 6? Nice shape? Also, rear spring shackle plates, nice?
Thank you
Loren </div></div>
(3)Three Screw Caps. Both parts are in nice shape like header indicates. Can send pics if you like Thanxs Dave
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
Old 12-28-2012, 03:45 AM
Not sure if they are different but there are 3 caps on the screws that hold the bottle bracket to the bracket that is screwed to the inner fender and then 3 on the screws that come up thru the inner fender into that bracket. If they are different do you know which of the 3 they are? Do the shackles include the bolts &amp; nuts?
Thank you
Loren
Old 12-28-2012, 11:48 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: camaro cat</div><div class="ubbcode-body">Not sure if they are different but there are 3 caps on the screws that hold the bottle bracket to the bracket that is screwed to the inner fender and then 3 on the screws that come up thru the inner fender into that bracket. If they are different do you know which of the 3 they are? Do the shackles include the bolts &amp; nuts?
Thank you
Loren </div></div>
The caps are for the washer bottle and not for the screws the come up through the inner fender. Those even though listed in the assembly manaul I have not seen ever in my 30 years of messing around with camaros. I have had several unmolested RS Camaros and they never had those little ones. The shackles do not include the bolts and nuts, just the 4 plates or shackles. Thanxs
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
Old 12-29-2012, 04:02 PM
OK, I had to think real hard about it. Spending $100 for 3 small plastic caps seems crazy but this is the only set I have ever come upon. If they where assembly line installed, and you might send me a picture first,I'll go ahead. Let me know what I need to do. On the shackles,I really need the bolts &amp; nuts the most.
Thank you
Loren
Old 01-06-2013, 03:20 AM
What happened here? I said I would take them and left a pm but never heard back. Can I assume the screw caps are gone?
Loren
Old 12-28-2012, 03:28 AM
Jonesy's Avatar
Jonesy Jonesy is offline
I will take the 1968 November Dated Jack/Mast (8K) $100.00.
Let me know shipping to 55811 and how you want to be paid.
Thanks
Mike
Old 12-29-2012, 04:41 PM
x77-69z28's Avatar
Dave , I will take the shackles if still available.
Buddy
Old 01-10-2013, 03:22 PM
My ph # is as follows: 484-753-1371. Sorry I typed in the wrong number above
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
