Old 12-26-2012, 05:18 PM
69VN's Avatar
69VN 69VN is offline
Default 1967-69 Camaro/Firebird Fan Shroud Retainer Kit SB
This is a slightly used 1967-69 Camaro/Firebird fan shroud retainer kit for a small block engine. These two clips are used to hold the lower part of the fan shroud to the radiator on the passenger side and to the radiator support on the driver's side. They are assembly line correct. *Asking $16.00 shipped to lower US 48 states/Canada extra. Pm me with any questions. Thanks.
