Old 12-23-2012, 02:07 PM
dlv4540 dlv4540 is offline
Default 1966-71 Square Port Heads, Blocks and Parts
1967-69 3919840 heads with sets and singles with various date ranges.
1967 3904391 March set and November single K-21-6
1968 #323 casting L78 396 dated I-2-7 standard bore T0926EG $1750
1969 #272 casting L78 396 rebuilt shortblock dated H-9-8 30 over $2500
1969-1970 3963512 427 & 454 2 and 4 bolt blocks
1969-70 3964291 heads and singles with various dates
1971 3994026 heads both dated I-9-71 $1250
3999289 casting 4 bolt stamped T1202LO for a service replacment 427-430HP 1969 corvette.
7115 steel crank $1000
7416 steel cranks $400
6223 steel cranks $300
1969 427-435HP 4 bolt block #439 casting F-14-8 stamped T1011LX freshly bored 60 over with all machine work done ready to build.
1966 3885069 intake 12-2-65 center plenum removed $350
1966 3789733 4 speed flywheel K-24-5 $125
1969 350-300HP motor complete intake to pan w/ 186 heads $1000
Richmond rebuilt 4 speed with shifter and linkage $1250
11 to 1 30 over 427 pistons with 7/16 dimple rods and a steel 6223 balanced crankshaft to the pistons and rods $1000
Chrome dipstick $10
8 inch factory harmonic balancer $150 #0325
Heads starting at $500 and up
Blocks starting at $750 and up
Cranks starting at $300 and up
330-770-2517 for any questions or pictures needed. Can ship if you cannot pick up.
Dennis Vugrinovich
Old 01-04-2013, 01:48 PM
Default Re: 1967-71 Square Port Heads, Blocks and Parts
Updated
Dennis Vugrinovich
