Old 11-24-2012, 03:45 PM
69VN's Avatar
69VN 69VN is offline
Default 1970-81 F-Body Park Brake Cable Bracket
This is a used GM park brake cable that bracket was removed from my 1970 RS back in the '90's. GM part number is clearly visible on the back #3983022. It is used to hold the rear cables where they pass through the unibody at the rear leaf spring pocket. It has been bead blasted and primed and is in great shape. I understand that 2 are required per car but I could only find the one. Can be used on Camaros from 1970-81. Asking $25 w/shipping included to U.S. 48 states/extra to ship to Canada.
