Old 11-22-2012, 02:21 PM
69VN's Avatar
69VN 69VN is offline
Default GM AC Delco Brake Lamp Switch
This is a NEW unused original AC Delco service replacement switch for use on various applications. This switch operates the rear brake lamp when the brake pedal is depressed. Part #1261219 can be used on all Camaros from 1967-79 w/o Cruise, w/o Power brakes. Check your application. *Asking $15 with shipping included to lower 48 states/outside U.S. extra.
