Old 11-04-2012, 11:38 AM
69VN's Avatar
69VN 69VN is offline
Default Original GM #346222 RH Exhaust Manifold
This is a used original GM exhaust manifold part casting #346222 RH (non-smog/small block). It is dated K 29 7 which is November 29, 1977. This manifold has the correct mounting holes for a stove pipe. If you plan to use a stove pipe 3 of 4 tiny holes have to be tapped out in order to properly mount the stove pipe. This manifold was basically used on camaros, novas, chevelle/malibu and monte carlos with 307, 350 and 400 engines. It has been bead blasted, cleaned and painted with a high-temperature cast paint. It is in excellent shape with NO cracks, welds or defects anywhere. Studs are perfect. Asking $125.00 plus shipping. Feel free to ask any questions. Thanks for looking.
SAL
