Old 11-02-2012, 12:19 PM
69VN's Avatar
69VN 69VN is offline
Default 1969 AM/FM Radio Fader Harness Switch
This is a used original GM fader harness switch for an AM/FM radio for stereo sound. This fader switch is used to send the signal to the rear speakers. It was removed from my '69 Camaro radio and it measures 12 inches long wire end to wire end. It has the correct black, green and white wires with a switch on one end and plug on the other. Has minor surface rust on the switch end with some of the original black finish gone but for the most part it is clean and 100% funtional. I had the switch tested at Mike Hagan's Antique Auto Radio http://mikehaganantiqueautoradio.com/ radio repair shop. This is a rare, hard to come by switch for your original am/fm radio. *Asking $45.00 with shipping included to lower 48 states. Feel free to ask any questions. Thanks.
SAL
