Old 11-01-2012, 09:17 PM
69VN's Avatar
69VN 69VN is offline
Default Original GM Bumper Jack Dated 9K
This is an original used GM bumper jack. Comes with the rachet assembly for the load rest and shaft ONLY as pictured. I do not have the original load rest. Has minor surface rust and will need to be replated and painted if you plan on using it in a show car. The rachet assembly is very functional and the overall condition is good. It has a date code stamped 9K (November, 1969) on the rivet of the bracket. Asking $125.00 plus shipping. Please ask any questions you may have. Thanks.
SAL
