Old 10-25-2012, 03:01 PM
7TL34 7TL34 is offline
Default Choke unit - ??
Anyone have an idea what this is for? Quite sure it is GM, came in a box with other GM stuff. Measures 2"x1"x1 1/2"h. Has "71" & "12" stamped on the base. Looks nos. [img:center][/img]
Old 10-25-2012, 04:33 PM
Default Re: Choke unit - ??
Choke Stove or Choke Pull off for a Q-Jet. Not an expert, but I'd assume the 12 and 71 are production dates??? December 71???
Blair
1968 L71 Corvette Coupe
1967 L30 Chevelle Malibu
Old 10-25-2012, 05:41 PM
1972 Pontiac (and possibly other GM) V8s. It is the same one as on my 455. It is a one-year part as the mounting posiition in 1972 switched from being perpendicular to the carb to parallel to it in 1972. Different V8s had different thermostatically calibrated coils and different vertical links, as well.
In 1973 they stopped using the choke stove system and went to a hot air tube, instead.
Do I win the prize for guessing the right answer? It is date code correct for my Canadian Firebird from Surrey, B.C.! [img]<<GRAEMLIN_URL>>/grin.gif[/img]
Old 10-25-2012, 09:15 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: njsteve</div><div class="ubbcode-body">1972 Pontiac (and possibly other GM) V8s. It is the same one as on my 455. It is a one-year part as the mounting posiition in 1972 switched from being perpendicular to the carb to parallel to it in 1972. Different V8s had different thermostatically calibrated coils and different vertical links, as well.
Do I win the prize for guessing the right answer? It is date code correct for my Canadian Firebird from Surrey, B.C.! [img]<<GRAEMLIN_URL>>/grin.gif[/img] </div></div>Thanks for the info &amp; pic. Which Surrey B.C. dealership did your Firebird come from? I live real close. - Dale
Old 10-26-2012, 10:59 AM
Actually it was sold new at London Motor Products in London, Ontario but in 1986 the original owner sold it and it wound up in BC from then on. I have the whole thread n the Pontiac section here on the site.
https://www.yenko.net/ubbthreads/ubbt...opics/505192/1
