Old 10-10-2012, 12:49 PM
JRSully JRSully is offline
Default battery swelling and leaking
Took the rod out the other day and when I got back, noticed the battery case was swelled and was just starting to leak a tiny bit of acid through the seams, glad I got it home before kaboom. Never had an overcharging issue ever, battery is a sealed Delco about 5-6 years old, stays on a battery tender most of the time, never any battery issues prior to this. Pirkle rebuilt V.reg and Alt have always worked fine with only about 5-6k miles on the car in last 5 years or so.? Thoughts.? Tired battery.? Thx
71 Porsche 911 Targa
Old 10-10-2012, 03:08 PM
Default Re: battery swelling and leaking
----Im guessing just age. Almost anytime they bulge they dont have much more time left. If its been completely discharged a lot it also doesnt help, but there are always anomalies. I just replaced the original battery in my 1990 560 SEC Mercedes. Thats "way" the exception to the rule. Not bad for 22 years, huh?......Bill S
Old 10-11-2012, 04:40 AM
Kurt S Kurt S is offline
Voltage at idle and at 2500 rpm is?
Kurt S - CRG
Old 10-11-2012, 05:57 AM
wagonman wagonman is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Kurt S</div><div class="ubbcode-body">Voltage at idle and at 2500 rpm is? </div></div>
These are important questions..........However,I would not check it with the swelled up batt........Use a new one or good used if you have other rides you can borrow from.
1969 rs/ss 396 350hp/4spd conv
1968 Z/28 crossram- j/l8 conv
1963 nova ss 350/4spd conv
