Old 10-07-2012, 04:05 PM
elonblock elonblock is offline
Default Car storage and rodents
What products have worked best in preventing mice from making a home in your car while in storage? And where do you place or use the products? Inside, or outside the vehicle?
Thanks!
Elon
69 COPO Camaro
Old 10-07-2012, 04:09 PM
Woj's Avatar
Woj Woj is offline
Default Re: Car storage and rodents
I've heard that an exposed bar of soap in the car will do this. I do it every year. So far no rodents. I keep a bar of soap and a box of charcoal in each trunk and interior.
Also, another member here told me several years back to lower the sunvisors. The critters like to perch on there then eat into the headliner.
That is where I've seen most headliner holes, just above the visors.
Phil Woj.
Old 10-07-2012, 04:19 PM
markjohnson's Avatar
markjohnson markjohnson is online now
I've always heard (and had good luck so far) with scented fabric softener dryer sheets thrown into car. I also try to keep those glue traps close to garage floor walls. I know them lil' bastards are around too because I've actually seen them scurrying through the grass when I mow the lawn and my next door neighbor is always complaining about them being in his house actually.
Old 10-07-2012, 05:18 PM
Pulnaway Pulnaway is offline
Its funny that this be brought up now. I just pulled our vett out of a long storage to start the restoration and the aircleaner..outside of the filter was full of bird seeds.
Scott
Old 10-07-2012, 10:20 PM
x  Baldwin  Motion's Avatar
I put moth balls in the ashtrays, and especially around the boot where the mice can get up around the shifter hole. Also use those little bags of mice "food" (last meal I would guess) just inside the garage doors where they may get in through cracks.
Old 10-07-2012, 10:37 PM
mmcporter's Avatar
mmcporter mmcporter is offline
Send a message via AIM to mmcporter
I take a multiple angle approach - I put Ivory Spring soap on top of plastic store bags in the trunk, each footwell and under the hood. In the garage itself, I put the poisonous food that will kill the mice should they ever get in. I plugged in an ultrasonic "noise maker" repellant also, but don't really believe it helps much.
Old 10-07-2012, 11:55 PM
JRSully JRSully is offline
I actually let my cat into the garage on a very regular basis and have her crawl all around the cars, it gets her scent eveywhere, which the mice don't like. So far, so good, not a hint of rodents anywhere
71 Porsche 911 Targa
Old 10-08-2012, 12:13 AM
427.060 427.060 is offline
Irish Spring soap slivers and/or Bounce dryer sheets.
James
1968 Beaumont SD396
Old 10-08-2012, 12:26 AM
396L35's Avatar
396L35 396L35 is offline
I hang moth balls in old nylon stockings and it seems to keep the mice and spiders away.
Mark
Old 10-08-2012, 01:19 AM
BARRY BARRY is offline
i have put irish spring soap in my car to find the bars half eaten
Barry Allan
