Old 09-30-2012, 02:59 PM
m22mike's Avatar
m22mike m22mike is offline
Default 502 Crate ?
Will all OE accessory brackets fit up to a modern crate motor like the 502 ?
Like 1969 BBC A/C, P/S brackets.
Thanks Mike
Old 09-30-2012, 04:49 PM
Donnie's Avatar
Donnie Donnie is offline
Default Re: 502 Crate ?
Yes Mike,
at one time I had a 502 in my 70 Chevelle dressed factory stock and its an A/C power steering car. only problem was no mechanical fuel pump.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 09-30-2012, 08:34 PM
m22mike's Avatar
Yea, how did the electric pump work for you ?
Mike
Old 10-01-2012, 01:50 AM
Donnie's Avatar
it was mounted in the back, but you could see some of it hanging from the back of the car. if I was to do a crate motor again I'd go with the 454 you can put a mechanical pump on it.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 10-01-2012, 03:41 AM
m22mike's Avatar
My thoughts too, I like the 502 in my buddies car, but I don't like the E-pump.
Thanks Mike
Old 10-01-2012, 03:55 AM
Does that apply to the 572 as well?
Old 10-01-2012, 03:56 AM
Woj's Avatar
Woj Woj is offline
Mike,
I don't like the fact of having to rely on an electric pump with the 502, but I must say that I have gotten used to hearing it. I've never had a problem with fuel supply, or leaking. The pump is nestled away above the axle (no chance of hitting). Only drawback is that you hear it when parked and idling. The performance is well worth it.
You should post a picture of what you have in mind to put it in??
Phil W. [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
Old 10-02-2012, 05:34 PM
68z 68z is offline
Mike, my 502 Bowtie block runs a mechanical fuel pump Nick
Old 10-02-2012, 08:59 PM
m22mike's Avatar
Nick
Are we talking about a new GM perfomance crate 502 ? There is now provision for the mechanical pump.
Mike
Old 10-02-2012, 09:35 PM
Gentleman, there is a GM &quot;Marine&quot; 502 - non fuel pump, and then there is a later GM 502 with fuel pump. I believe they only made a low number production the later GM 502.
