Old 08-27-2012, 01:02 AM
Chevyfever Chevyfever is offline
Default u-coat it floor coating
I have floor coating that lifted under one tire and has been down
for one year.I contacted manufacture twice and they have promised to
send a test kit for a sample.Just curious if anyone has had like problem with u-coat it?
Bernard
Old 08-27-2012, 04:30 PM
ohhawk ohhawk is offline
Default Re: u-coat it floor coating
Have a neighbor that applied UCoat it maybe 6-7 years ago and has had a similar problem. Problem started showing up within a couple years of application. We're in a climate that gets the hot summers and cold winters if that makes a difference. They also put a salt brine on streets at times in the winter.
He's usually pretty particular with things so I wouldn't think it was in his lack of preparation with the surface. Floor currently has many areas of lift now.
Dick
Old 08-27-2012, 04:34 PM
Where is almost heaven?
Old 08-27-2012, 04:57 PM
PxTx's Avatar
PxTx PxTx is offline
I'm thinking John Denver- West Virginia?
Paul III
Old 08-27-2012, 10:22 PM
Jack_Tar Jack_Tar is offline
Check to see if the wheel where the coating lifted has <span style="text-decoration: underline">any</span> break fluid weeping from that wheel Caliper/cylinder. If so, even just a minuscule amount will eat up the floor coatings. Gas won't tear them up (as fast) and oil won't damage them, but break fluid will kill them.
Jack Tar (Old English Slang for Sailor)
Old 08-27-2012, 10:28 PM
dvss1 dvss1 is offline
I tried the u-coat too and it lifted and they gave me the same song and dance with the test kit. After 5 calls I was thru with them. Since then, I redid my floor with the coating they use in aircraft hangars. It's 3 parts a acid to etch the concrete, a primer and then the base. It's been 10 years and I have not had anything pull up, rip, or crack. I have had everything from cars, big trucks, combines, and halftracks on it. Really great stuff, only kickback was the price.
Old 08-28-2012, 04:30 AM
Thanks for all the feedback,i prepared floor exactly per instructions.
I have called twice and test kit is in mail still waiting,the floor has
not had any hard usage.Has only had couple oil spots in a different location,as of now i would not recommend u-coat it.I will update with
outcome, may prevent a headache for others:Yes it is West Virginia.
Bernard
