Old 08-26-2012, 01:21 AM
lbnaz lbnaz is offline
Default 69 302 CE9 Short Block Value
Hello, checking to see what a 69 302 CE short block is worth approx. The casting number is 3956618 dated C249 and stamped CE9A44889. The motor has been in sorage for over 30 years and just sold to settle an estate. It is complete still assembled with all GM parts including the cam. I boxed the lifters accordingly to where they were on the cam. Has the TRW std. 2172 pistons with no ridge in the cylinders at all. Has the GM 1178 crank still with blue paint on it. The pink rods still have paint on them. The engine was taken apart years ago and balanced you can see where the rod ends were ground. Still has the green paint on the cam in places. I checked it before removing heads (66 462's)and it was gapped for a solid cam. Has the GM oil pump, oil pan with trap door and harmonic. Looks like you could regasket it and fire it. Larry 520-349-2337
Old 08-26-2012, 09:01 PM
x77-69z28's Avatar
Default Re: 69 302 CE9 Short Block Value
someone had advertized an nos crate CE shortblock in the crate a few months back for $3500. i would say around $2500.
Old 08-26-2012, 10:52 PM
Guest
Posts: n/a
As you have described it I would say minimum $4500.
Old 08-26-2012, 10:59 PM
1969z280 1969z280 is offline
X2
... some old Chevrolets and Pontiacs.
