Old 08-09-2012, 03:14 AM
Guest
Posts: n/a
Default New & Used 1969 Camaro & Nova Parts...
New & Used 1969 Camaro (& Nova) Parts…good, bad and ugly...L-O-L.
(unless noted, all of the parts below are for 1969 Camaro & Nova)
New Old Stock GM Rag Joint. Part Number 780639. $125.00
New Old Stock GM Nova Headlamp Bezel. Part Number 03949790. $169.00
Delphi Manual Steering Box (525 box, standard ratio), new in original box. $333
L88 LS6 L71 L72 ZL1 Chevrolet Corvette, Camaro, Chevelle Big Block Rocker Arm studs, 7/16. New Old Stock OEM Chevrolet. $40.00
Small Block Crankshaft Pulley. Car had power steering. Pulley is in very nice overall condition. $29
Small Block Water Pump Pulley. Very nice overall condition. $29
Alternator Pulley. Standard groove configuration. Very nice overall condition. $10
Small block (motor) frame mount brackets. Engine mount pads @ subframe. Mint OEM used. $40
Automatic Transmission Brake Pedal. GM. Mint used. Includes perfect OEM pad, bushings & cross shaft . $40
Heater Hose Clip. Clips to passenger side inner fender. GM. Mint used. $8
Vacuum Advance Tube Clip. Small block. Mint. OEM Used. Difficult to find part. Fits on passenger side of intake manifold to hold vacuum advance steel line in place. $10
Front Drum Brake Assemblies. Complete. Mint. Came off 9300 original mile car. $150 pair
Front Drum Brake Hubs. Mint. Came off 9300 original mile car. $50 pair
Front Park Brake Cable. Mint. Came off 9300 original mile car. $35
Rear Park Brake Cables (Nova). Mint. $50/pair
Raybestos “Raymold” Bonded Brake Shoes (rear set). P/N 242RP (Camaro-Nova-Chevelle, etc.). New in box. $24.00
1967-68 Camaro; 1968 Nova Big Block Water Pump Bypass Hose. New Old Stock GM. $35.00
Small Block Heater Core. Perfect shape. Includes seal. $39
Windshield Washer Jar. Has some yellowing, but otherwise perfect. $9
Small block valve cover to air cleaner hose, pipe, grommet & clamps. Mint. $5
Side marker lens assemblies, new. Complete set of 4. No chrome trim. $25
Twist in oil filler cap. Very nice painted original. $7
Mirror base gasket (driver side) $1
Wire gutter (at firewall cowl); one hole has a tear in it. $1
Automatic transmission reverse interlock. $20
Steering rag joint. Very nice condition. $25
Fan clutch (1968 Nova & 396 Camaro). New. Reproduction $150
Stick shift pedals (pedals only; no clips or bushings). New. Reproduction. $75
Aero wiper blades. New. OEM Style Reproduction. $50
Column shift steering column, partial. Includes lower + Upper key/turn signal housing & shifter housing. Very nice condition. Upper key/turn signal housing has small flat dent. $40
Hood to cowl ledge weatherstrip. Nice shape. $5
Powerglide Transmission kickdown rod. Good shape. $5
Carburetor air cleaner wing nut. Correct original. $5
Rubber hood bumper set. Used. Decent shape. $2
Windshield wiper motor mount bushings. Good condition. $2
Front brake hoses (drum brake). Good condition. $10/pair
Correct distributor clamp with correct hold down bolt. Nice shape. $49
Internal horn switches (inside steering wheel). Mint. $5
Nova Trunk Lid emblem. Mint OEM GM part. $35
Original Nova Gas Tank. **Tank is Damaged**. Has a dent on one side. Includes a mint sending unit. No cap. $69
1969 (&1968) LH Nova Tail Lamp Housing. **Housing is Damaged**. $5
1969 (&1968) RH Nova Tail Lamp Assembly. Very Nice Condition. Complete. $50
1969 (&1968) LH Nova Tail Lamp Lens Assemblies, including gasket. Very nice condition. $15
Nova Tail Lamp to Body Gaskets. OEM GM. Very Nice Condition (Pair) $5/pair
Nova script front fender emblems. OEM GM. Nice shape. $20 each
Shoulder harness strap. Pale green in color. $2
1969 (&1968) Nova Park lens gaskets. Nice shape. $1
Nova Front bumper bracket, passenger side inner. Fresh powder coat. Mint. $15
Nova Front bumper bracket, passenger side outer. Dented. Can be repaired. $5
Nova Hood lip molding (chrome trim for nose). Reproduction. Minor dents (can be repaired). $30
Nova Hood emblem. Reproduction. Not perfect; has minor ripples in it (driver quality). $20
__________________________________________________ ______________
E-Mail: wscraba "at" telus.net
(swap the "at" for @)
Thanks for the room Yenko.net!
Wayne
