Old 08-07-2012, 01:29 PM
Fast67VelleN2O's Avatar
Default Holley carburetors (GM, Ford) some aftermarket too
3124 Service Dated 944. Complete core. Correct 4456/4519 blocks. $450.
3130 Service Dated 864. Repaired baseplate and choke assy missing. Correct 4596/4519 blocks. $200.
4346 Service Dated 2377. Repaired baseplate and choke assy missing. Correct 5583/4519 blocks. $225.
3839 Dated 684. Missing choke pull off otherwise complete. Correct 5277 block. $225.
3810 Dated 6B1. Missing choke assembly. Correct 4743 block. $300.
4296 Service Dated 2947. No choke assy. Does not have GM part number on choke horn. Correct 5895/5901 blocks. $325.
3418-1. Service Dated. Complete carb. Wrong front metering block. $300.
3811 Dated 742. 100% Complete carburetor. Correct 4796 block. $675.
4492 Dated 9B2. Wrong baseplate & front block. Correct 4519 rear block. Converted to rear squirter. $200.
4279 Dated 895. 100% Complete. Correct 5673/5671 blocks. Still has Autolite tag. $675.
4493-1 (forget the date). Missing choke assembly. Correct 6203/6207 blocks. $300.
Pair of 4224 Center Squirters. Choke horns milled off. Otherwise complete cores. $375 pair.
Holley 3 Barrel 1050 CFM. Complete and correct core. $300.
Holley 3 Barrel 950 CFM. Complete and correct core. $300.
-Matt
Day 2 is Life.
