Old 08-01-2012, 04:56 PM
enio45 enio45 is offline
Default 4 Sp cross member to the subframe
I'm in the process of assembling a subframe for 69 Camaro Z28
The bolts that hold the cross member to the subframe - im told the correct bolts have a flanged head and the bolts go up thru the frame with the nuts on top of the subframe. HBC has a set of bolts that im told is incorrect...i don't know?? Also the HBC bolts have only 2 washers for 4 bolts?
Anyone have an orig car where the cross member has been removed and can tell the type of bolts, washers and nuts that are correct and the orientation?
Thnaks SYC
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
