Old 07-31-2012, 03:33 AM
bbbentley's Avatar
Default 1969 Big Block Chevy alt. brace
need original brace (flat with 2 holes) that goes on rear of alternator for 1969 only Big block 396. Also looking for survivor quality used PCV hose (original GM parts only), used Fuel line from pump to carb, starter wire clip for L78 396/375, In addition, but not as urgent would be correct smog diverter valves, 1105 P.S. pulley, 2458 Smog pulley 499 dist. before 11-68 for same engine for survivor grade resto. Thanks,James 937 515 353seven.
Old 07-31-2012, 10:52 PM
Unreal Unreal is offline
Default Re: 1969 Big Block Chevy alt. brace
Shouldn't that have the spacer installed in one of the holes to align with the smog pump? I think I have one, but don't know what it's worth.
Old 08-01-2012, 06:32 AM
bbbentley's Avatar
Don't think it has anything to do with smog pump. It bolts to back of alternator and other end goes on lower long bolt that goes through alternator along with a spacer and lower bracket(I have everything but the brace). I have the smog pump and bracket as well. I have the correct lower bracket for alt. with rivet in center that smog pump bolts through. The brace is flat,aprox. 3 inches long with hole at each end and a mnfg. stamp of "V" and is a '69 only part.
FULL OWNER HISTORY
Old 08-01-2012, 05:07 PM
MosportGreen66's Avatar
Do you need original PCV square edge clamps or original fuel square edge clamps? If so, I have a healthy stock of both.
Let me know... thanks
Old 08-02-2012, 02:52 AM
OK, when you said the flat bracket, I thought you were talking about the lower alt bracket that also holds the smog pump. 69 was flat, and had a spacer, and later years had an offset, instead of the spacer, to properly align the smog pump. Good luck with the hunt.
Old 08-03-2012, 07:46 PM
ssl78 ssl78 is offline
I have a 8h28 499 distributor
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
