Old 07-21-2012, 03:12 AM
TT427Vette TT427Vette is offline
Default `98 Twin Turbo Vette
Not your everyday Vette...has not been on the dyno but a milder similar build made over 1000RWHP!!!
Street friendly / real head turning car...Don`t want to sell her, but with my business I don`t have time to enjoy her plus the kids college is coming up... need I say more??
1998 C5 Corvette 427 C5R based twin turbo with billet bellhoused 4L80E transmission. The car has 45,000 original miles. Car looks like show room inside and out. Custom motor / turbo setup / interior. This project has been a long time in the making with a lot of one off custom pieces. All parts are top of the line...done to the extreme.
Engine:
Block: C5R Aluminum Race block. Completely deburred, honed with deck plate. Billet main caps. 6500.00 new
Crank: 4.00 Callies lightweight racemaster crank. Knife edged / drilled / radiused journals / beveled oil orifices / keyed
Rods: Oliver Billet heavy duty rods with ARP bolts.
Pistons: Weisco Custom one-off (not off the shelf) forged pistons. 42cc reverse dome. Thermal top coating, Anti-scuff side coating, Anti-detonation grooves. Designed for this turbo application.
Tapered heavy duty / light weight Weisco wrist pins / spiralock
Rings: Weisco tool-steel top ring, Ductile 2nd, low tension oil rings. This setup was made for extreme abuse.
Cam: Custom Cam Motion turbo billet / riffled drilled grind
Clevite Coated rod and main bearings
Clevite cam bearings
C6 oil pan with windage tray
LS3 high volume GM oil pump
Evans High flow water pump with Evans waterless coolant / hard anodized pulley
SFI approved ATI keyed harmonic balancer
A-1 Technologies MP-35 Alloy studs (main)
A-1 Technologies MP-35 Alloy head studs (stronger than any ARP bolts). These head studs cost 1000.00
Felpro MLS Perma-seal head gaskets
Crane billet timing set
C5R Timing Chain tensioner (100.00 unit)
90mm Wilson FAST intake with all stainless hardware
Nick Williams Billet / polished 90mm throttle body
Kinsler high flow polished custom aluminum fuel rails
Heads:
AFR Castings / Custom CNC’d by ET Performance. Assembled by Extreme Cylinder Heads. All seats / inserts / seals / hardware are for extreme turbo conditions. 5500.00 for hardware and labor..this does not include the castings or CNC work. Ferrara Extreme duty SS valves / Seats are copper beryllium / guides are Copper beryllium high temp heavy duty units / Psi double springs, shot-peened, polished 220 lbs on the seat 480 open. Cyclone titanium retainers / 7 degree tool steel locks / high temp stem seals / Flow numbers available of interested in purchasing. 250cc intake runner.
Jesel Y2K adjustable rockers with tool steel push rod cups / full c-cliped roller tip.
Trend heavy duty 210 degree end push rods
Morel billet High RPM / high performance link bar style lifters / allow for 7500rpm / high seat and open pressures.
Engine Management:
Big Stuff 3 with wide band oxygen sensor and internal data logging option. Also has the transmission control option. Not used. This car has a Compushift control unit with custom display and control unit. Transmission control can be modified on the fly.
Relocated Coils with Magnacor custom 9mm wires. Cool Sox on plug ends. NGK 7 iridium plugs
Katech aluminum (red wrinkle powder coat) valve covers with moroso anodized aluminum baffles. Canton -12 triple crankcase breather system.
Race Poven Nascar custom 160amp relocated alternator / Custom laser cut alternator bracket with secondary aluminum tensioner pulley. Katech custom billet adjustable tensioner
Turbo system:
All hot side and cold side piping is original PTK product (not overseas junk). All hot side piping coated in Techline high temp satin black. All cold side piping chromed.
Turbos 67mm Precision water cooled / ball bearing units. Polished compressor housing / thermal coated exhaust housings. Custom Iconel heat shields (600.00 for the set)
38mm turbosmart waste gates / 50mm Tial blow-off valve
Turbosmart Eboost 2 mounted on pillar pod with dual solenoids
Custom air to air intercooler
BeCool radiator with custom shroud / Bosch 5000cfm dual fans / custom cooling remote reservoir
Earls custom transmission and oil coolers
Custom brake reservoir heat shield
All hoses/lines either crimped or aluminum style SS of lightweight shielding
All New AC components including GM compressor
90% ARP fasteners
95% GM gaskets
Body:
Custom carbon fiber "Functional" Stinger Turbo hood
New Lexan top
Paint job near mint. Car has been covered and garage kept
Stainless B&B exhaust / 2 ˝ piping with QTP electric cutouts
Custom interior matching fuel gauge in pod
Brakes :
Drilled and slotted rotors / New GM pads / Tires like new.
Transmission:
Custom late model 4L80e conversion. This conversion has all the top of the line internal components. It has a Custom billet aluminum bell housing. Custom 4340 output shaft. Yank SC3000 turbo converter. Compushift electronic transmission control with custom display mounted in custom dash panel. All new drive shaft bushings (Harder more durable GM units / not BMW units.) Custom HD aluminum drive shaft with billet mounting ends. Dynotech built 3:15 rear / micro polished gears / shot peened and debured case / hardened 4340 output shaft /
Fuel system:
Can hande 2000hp. Intank custom assemble (essentially duplicates the stock pickup design) but has -10 out of the tank to a magnafuel mp4340 continuous duty fuel pump. Y’d to -8 to each rail. Each rail out to a 1:1 pressure controlled Magnafuel fuel regulator. -8 back to the tank. Fuel system operates the way it is designed for GM. All fuel lines are Nascar style, lightweight teflon lined kevlar outer sleeve. Average price per for is 25.00-30.00 per foot. All ends are crimp style. Precision 96lb fuel injectors / flowed and tested
Z0-6 C6 shocks
Interior has custom leather “Twin Turbo” logos on dual gray and black seats. New Sport foam (complete set). Interior mint. Custom touch screen (pioneer GPS) receiver / custom radio bezel (double din)/ Compushift display mounted in dash. 2 MTX amps / 4 separate components / MTX 12" sub custom enclosures with “Corvette” logo.
ESC Methanol:
Custom SS Methanol tank inside drivers side fender with fill in cowl area / control mounted in dash panel.
Wolfe bolt in 6 point roll cage with swing out drivers door.
Wheels are black and silver Z0-6 inspired.
Custom brackets and dual seat bell harnesses.(red)
Car is a real must see. Runs smooth...very streetable...I drove it up to Chicago from Florida!
This car only has less than 4,000 miles on the trans/engine/drive train/turbos. Over 120,000.00 invested.
After buying the car a little shy of 3 years ago she got away from me and had a fight with a fence [img]<<GRAEMLIN_URL>>/cry.gif[/img] I had to have the radiator, and intercooler replaced, other than that it was cosmetic, front bumper, and doors. Sounds worse than it actually was, just wanted to do it right and show I`m not trying to hide anything.
Lots of pics can be found here:
http://luckydogcharters.com/Vette.php
Click on the thumbs for a larger pic.
$56,000 OBO
Jim
Captain Jim Kaske
&quot;Lucky Dog Charters&quot;
(847) 812-1436
http://www.luckydogcharters.com
Old 07-21-2012, 04:43 AM
Default Re: `98 Twin Turbo Vette
Oh man I could get in trouble with that...
Old 08-31-2012, 05:53 PM
<span style="color: #FF0000"> Tough economy... now asking $48,500...</span>
Functional carbon fiber &quot;Stinger&quot; hood...
New custom embroidered seat covers and foam...
LS1 427&quot; twin liquid cooled ball bearing turbos...
C5R GM aluminum racing block...
Fender mounted stainless methanol tank...
Pod mounted eBoost2 and fuel pressure guages...
Z06 style rims...
<span style="color: #FF0000">Asking $48,500</span>, can`t duplicate for twice the price!... A/C worked fine this past summer [img]<<GRAEMLIN_URL>>/wink.gif[/img]...(847) 812-1436
Old 08-31-2012, 06:49 PM
Jim,
Welcome aboard, get it [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
Great Vette Build [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] Good luck with the sale.
I like what Lucky Dog has to offer.....I just may book you next summer.
Old 04-03-2013, 04:45 PM
Spring is here, and I have two kids looking at college brochures that are arriving in the mail on what seems to be a daily basis [img]<<GRAEMLIN_URL>>/frown.gif[/img]...&quot;Oh look this ones only $$$ a year&quot; if they only knew [img]<<GRAEMLIN_URL>>/dunno.gif[/img]... unfortunately their education comes first...tuition is going to be a killer [img]<<GRAEMLIN_URL>>/mad.gif[/img]... drop in price... first <span style="color: #FF0000"><span style="font-weight: bold">$40,000</span></span> takes her...
Jim
Old 04-03-2013, 07:38 PM
Wow! This Corvette is still available.....that is a killer car for $40K.
