Old 07-19-2012, 12:55 PM
John's Avatar
John John is offline
Default 1965 Plymouth Belvedere Max Wedge tribute
Wanna go Nostalgia racing ?
Here you go.....
....... This car was once owned by Tom Sneden,
........ Driver of the Bob Banning Dodge sponsored Factory Lightweight drag car
......... that was called "Bounty Hunters"
600+ HP 512 Cubic Inch Max Wedge
ENGINE
... 1968 industrial R/RB block bored and stroked to 512 CI/600+hp (440source kit).
... 1963/64 Max Wedge (MW) heads (4 bolt valve covers) with MOPAR Performance (MP) .590 flat tappet cam
... MW cross ram intake manifold with Edelbrock carbs.
... Ignition is control by a Mallroy Unilite distributor and MSD-6AL control box.
... The engine is mounted with a motor plate and 1/2" fuel lines with a Holley blue fuel pump.
... Engine cooled by OEM 3 core radiator and high volume aluminum water pump.
... Exhaust handled by TTI 2" headers and 3.5" pipes to flow master mufflers, system ending at rear axle.
TRANSMISSION
... Auto 727 Transmission with 9" stall convertor (4500rpm)
... reverse manual valve body and column shift.
REAREND
... Dana 60 rear with 4:56 gears
... MP Super Stock springs which have been moved inward,
... coil over shocks
... frame tied
... 15 x 8 steel wheels.
EXTERIOR/BODY
... An older restoration, the body is solid and presents well, but could use some freshening up.
... Floor pans are complete with some thin spots.
... Original appearing trunk, with factory wheel wells remaining, battery re-located to the trunk with MP/Direct Connection battery box kit.
... Dealership metal tag from Essex Dodge Baltimore, MD still intact.
INTERIOR
... Styled after the A990 cars with A100 lightweight bucket seats on aluminum seat rails
... rear seat removed, carpeted plywood separating trunk of interior compartment.
Offered at $23,500 o.b.o.
Call 757-871-6799
.........to set a time to see this car.
[img:left][/img]
[img:left][/img]
[img:left][/img]
[img:left][/img]
[img:left][/img]
[img:left][/img]
[img:left][/img]
[img:left][/img]
Old 07-22-2012, 07:58 PM
John's Avatar
Default Re: 1965 Plymouth Belvedere Max Wedge tribute
New price ....
.... $23,500 o.b.o.
( I also edited the original post to reflect the new price. )
[img]<<GRAEMLIN_URL>>/flag.gif[/img]
Old 07-27-2012, 02:06 PM
John's Avatar
Just put in a new starter and went completely through the transmission with everything new.
.....This car is NASTY! [img]<<GRAEMLIN_URL>>/[/img]
.... and now at $23,500 [img]<<GRAEMLIN_URL>>/flag.gif[/img]
Old 07-31-2012, 04:35 PM
John's Avatar
Okay guys,
...I have it listed on Ebay.
...Reserve is $23,500
Good Luck [img]<<GRAEMLIN_URL>>/[/img]
Old 08-05-2012, 07:45 PM
John's Avatar
....This auction ends tonight... Good Luck [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 08-14-2012, 01:48 PM
John's Avatar
... It is back on ebay....
.... No Reserve !
Ebay - No Reserve - 1965 Plymouth Belvedere Max Wedge
Old 08-14-2012, 01:57 PM
Good looking car.
Old 09-17-2012, 06:27 PM
John's Avatar
.... New price .... $18,900
..... Come get it this week.....
.... or
.... I will take it to the Mopar Madness Event in Petersburg, Va.
.... and run the hell out of it!
Here is the event info....
http://vmpdrag.com/drag/MegaMoparActionSeries.aspx
[img]<<GRAEMLIN_URL>>/[/img] [img]<<GRAEMLIN_URL>>/[/img]
